Hello everyone!
We are trying to use QAssistant to show the help without success.
We have implemented a class that looks like ...
from PyQt4 import QtCore, QtGui, QtAssistant
class MainWindow(QtGui.QMainWindow, Ui_qto_main_window):
def __init__(self):
self.qto_assistant = QtAssistant.QAssistantClient('')
qto_args = QtCore.QStringList(QtCore.QString (QtCore.QLatin1String("-profile /tmp/test.adp")))
self.qto_assistant.setArguments(qto_args)
self.__connect_slots()
def __connect_slots(self):
self.connect(self.qto_action_help, QtCore.SIGNAL("triggered ()"), self.__help_slot)
def __help_slot(self):
self.qto_assistant.showPage('/tmp/doc/index.html')
When we invoke the help, nothing happens. And we have also tried, with the same result:
#Forget about self.qto_assistant attribute
qto_process = QtCore.QProcess(self)
qto_args = QtCore.QStringList("-collectionFile /tmp/test.qch -enableRemoteControl")
qto_process.start('assistant', qto_args)
if not qto_process.waitForStarted():
return
What is happing? How can we solve it?
Thanks in advance.
