Help b4 i go crazy
im very new shake and i have no idea on how to xport footage out it,pls help im trying to xport footage to be used for final cut pro but i use the fileout it just does not copy anywhere on the computer
fileout node is the render node you attach at the bottom
of your tree to render to a local drive or network drive.
are you using the right syntax for naming and padding conventions ?
syntax is extremely specific.
i am not familiar with shake on mac but
i would check and make sure for your file out naming
use something like this
myfile.#.sgi
myfile.%04d.iff
both will give you 4 digit padded sequence
myfile.%03d.iff
give you a 3 digit padded sequence
myqtmovie.mov
for quicktime fileouts
If you write an fileout without an extension and you haven
Aternatively, you could try reading the manual.
Note to all people new to Shake and looking for learning resources on Highend2d: We all learnt via the manual, you should too.
thanxxx very much for your help with im gonna try and see if this works regardless that's nfo i have than b4,and i try to read the manuali get confuse than b4 im more of a hands on,but this shake is amazing
anyone know what happen to the sound cause i render out shake to quicktime i get no sound how can fix thanxx for your help
