my pc: p3 800eb,256M,815e motherboard;Leadtek Geforce 2MX 32M
question:
1: cant find anything about maya 3d setting in control panel ,but the driver Detonator (i use 10.4)has NvWsApps.cfg,is more setting!!!but cant install on???
2:under 32k color,when use artisan or 3d paint,is slowly
and flip brush,
3:under 32k color,when loading a scenes with more objects;i use 6,7 key to switch shading or light,then switch
big window to small windows,then switch back,maya has
2-3 second waiting,and when all appear,maya run slowly!
later i find the floating windows is causation,you must close
all floating windows,then use 4 key to switch ,back to small
windows and switch back then,so it work good.. ..
so,i hope someone can answer why ?how to setting my
Gefore 2MX in maya3.0>???
o! i forgot! i find a joke!!! i have another pc ,is p2 350 256M
,BX motherboard, and Leadtek winfast 320(Riva TNT),only
16M for video card. i updriver from win2k 's Riva TNT (Microsoft) to Detonator (i use 10.4),hehe.. i find for maya and
more other setting in openGL control!! and my TNT Realy like
a TNT!!! it so fast! and artisan & 3d paint work good! you can
open all blur( liner, Grid..)in brush,and all work fast!!! but you
must in 16k color!
…Oh! …How can i do for maya???..my Geforce 2MX! why
so much Detonator for you? which is the best choice???
..somebody can Help me???>>>>(a minibabygirl)…
Sounds like your problem is more motherboard related. Try www.geforcefaq.com for ways to solve these kinds of problems.
Also, 16 is usually always faster then 32, especially the higher the resolution.
not all drivers have the maya settings
drivers are very picky and you may have to hunt around for the one that works best for your hardware.
sorry, I know what a pain that is, but there is a LOT of info out there to help ya. many posts on highend a lots of links around the web like the one I mentioned above.
Good luck ![]()
-G
Take a look at my Detonator examinations on:
http://eastvan.com/oc
10.80 should be the way to go for you. Try turning on the Overlays option in the OpenGL section. Crank up your RAM in Direct3D and OpenGL settings to their maximum (63/16 if I remember correctly).
The 815e board doesn’t have any of the AGP 4X issues that the VIA boards have, but it may be turned off in the BIOS. Take a look in there to make sure that AGP 4x is Enabled.
The Geforce2 SHOULD be faster…
Good luck,
Sean
