HELP?!?!? Image plane woes
I've set up my image planes to model a head. i've got the front and side image planes, just as any good-meaning modeler would set up. BUT--- Whenever i look through the front or side image planes, i can't see the geometry! it's like the image planes are in front of the geometry, and it blocks my view... if i turn down the alpha gain on the planes, i can just make out the outline of my object...but then i can't really see the plane too well. ANY IDEAS?!?!?
thanks,
Anth
if the image plane is blocking your model, select the camera then choose image plane on the channel box. adjust the center z option and move it back.
hope this helps...
