I have the same problem (FC5 Maya 8 Quadro 750 XGL), it's becoming quite frustrating.
I've tried what cobrana had suggested;
mv /usr/aw/maya/libgcc_s.so.1 /tmp
mv /usr/aw/maya/libstdc++.so.5.0.6 /tmp
ln -s /lib/libgcc_s.so.1 /usr/aw/maya/lib/libgcc_s.so.1
ln -s /usr/lib/libstdc++.so.5.0.7 /usr/aw/maya//lib/libstdc++.so.5.0.6
ldconfig
but that didn't help.
I am using the drivers provided by livna and glxinfo reports the following:
name of display: :0.0
display: :0 screen: 0
direct rendering: Yes
server glx vendor string: NVIDIA Corporation
server glx version string: 1.4
server glx extensions:
GLX_EXT_visual_info, GLX_EXT_visual_rating, GLX_SGIX_fbconfig,
GLX_SGIX_pbuffer, GLX_SGI_video_sync, GLX_SGI_swap_control,
GLX_ARB_multisample, GLX_NV_swap_group
client glx vendor string: NVIDIA Corporation
client glx version string: 1.4
client glx extensions:
GLX_ARB_get_proc_address, GLX_ARB_multisample, GLX_EXT_visual_info,
GLX_EXT_visual_rating, GLX_EXT_import_context, GLX_SGI_video_sync,
GLX_NV_swap_group, GLX_NV_video_out, GLX_SGIX_fbconfig, GLX_SGIX_pbuffer,
GLX_SGI_swap_control, GLX_NV_float_buffer, GLX_ARB_fbconfig_float
GLX version: 1.3
GLX extensions:
GLX_ARB_multisample, GLX_NV_swap_group, GLX_ARB_get_proc_address
OpenGL vendor string: NVIDIA Corporation
OpenGL renderer string: Quadro4 750 XGL/AGP/SSE2
OpenGL version string: 1.5.6 NVIDIA 87.74
OpenGL extensions:
GL_ARB_depth_texture, GL_ARB_imaging, GL_ARB_multisample,
GL_ARB_multitexture, GL_ARB_occlusion_query, GL_ARB_pixel_buffer_object,
GL_ARB_point_parameters, GL_ARB_point_sprite, GL_ARB_shadow,
GL_ARB_shader_objects, GL_ARB_shading_language_100,
GL_ARB_texture_border_clamp, GL_ARB_texture_compression,
GL_ARB_texture_cube_map, GL_ARB_texture_env_add,
GL_ARB_texture_env_combine, GL_ARB_texture_env_dot3,
GL_ARB_texture_mirrored_repeat, GL_ARB_texture_rectangle,
GL_ARB_transpose_matrix, GL_ARB_vertex_buffer_object,
GL_ARB_vertex_program, GL_ARB_vertex_shader, GL_ARB_window_pos,
GL_S3_s3tc, GL_EXT_texture_env_add, GL_EXT_abgr, GL_EXT_bgra,
GL_EXT_blend_color, GL_EXT_blend_minmax, GL_EXT_blend_subtract,
GL_EXT_compiled_vertex_array, GL_EXT_Cg_shader,
GL_EXT_draw_range_elements, GL_EXT_fog_coord, GL_EXT_multi_draw_arrays,
GL_EXT_packed_pixels, GL_EXT_paletted_texture, GL_EXT_pixel_buffer_object,
GL_EXT_point_parameters, GL_EXT_rescale_normal, GL_EXT_secondary_color,
GL_EXT_separate_specular_color, GL_EXT_shadow_funcs,
GL_EXT_shared_texture_palette, GL_EXT_stencil_wrap, GL_EXT_texture3D,
GL_EXT_texture_compression_s3tc, GL_EXT_texture_cube_map,
GL_EXT_texture_edge_clamp, GL_EXT_texture_env_combine,
GL_EXT_texture_env_dot3, GL_EXT_texture_filter_anisotropic,
GL_EXT_texture_lod, GL_EXT_texture_lod_bias, GL_EXT_texture_object,
GL_EXT_timer_query, GL_EXT_vertex_array, GL_HP_occlusion_test,
GL_IBM_rasterpos_clip, GL_IBM_texture_mirrored_repeat,
GL_KTX_buffer_region, GL_NV_blend_square, GL_NV_copy_depth_to_color,
GL_NV_depth_clamp, GL_NV_fence, GL_NV_fog_distance,
GL_NV_gpu_program_parameters, GL_NV_light_max_exponent,
GL_NV_multisample_filter_hint, GL_NV_occlusion_query,
GL_NV_packed_depth_stencil, GL_NV_pixel_data_range, GL_NV_point_sprite,
GL_NV_register_combiners, GL_NV_register_combiners2,
GL_NV_texgen_reflection, GL_NV_texture_compression_vtc,
GL_NV_texture_env_combine4, GL_NV_texture_rectangle, GL_NV_texture_shader,
GL_NV_texture_shader2, GL_NV_texture_shader3, GL_NV_vertex_array_range,
GL_NV_vertex_array_range2, GL_NV_vertex_program, GL_NV_vertex_program1_1,
GL_SGIS_generate_mipmap, GL_SGIS_multitexture, GL_SGIS_texture_lod,
GL_SGIX_depth_texture, GL_SGIX_shadow, GL_SUN_slice_accum
glu version: 1.3
glu extensions:
GLU_EXT_nurbs_tessellator, GLU_EXT_object_space_tess
visual x bf lv rg d st colorbuffer ax dp st accumbuffer ms cav
id dep cl sp sz l ci b ro r g b a bf th cl r g b a ns b eat
0x21 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x22 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x23 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x24 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x25 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x26 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x27 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x28 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x29 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x2a 24 tc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x2b 24 tc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x2c 24 tc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x2d 24 tc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x2e 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x2f 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x30 24 tc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x31 24 tc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x32 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x33 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x34 24 tc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x35 24 tc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x36 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x37 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x38 24 tc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x39 24 tc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x3a 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x3b 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x3c 24 tc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x3d 24 tc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x3e 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x3f 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 0 0 None
0x40 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 0 0 None
0x41 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x42 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x43 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 0 0 None
0x44 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 0 0 None
0x45 24 dc 0 32 0 r y . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x46 24 dc 0 32 0 r y . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x47 24 dc 0 32 0 r . . 8 8 8 0 4 0 0 16 16 16 16 0 0 None
0x48 24 dc 0 32 0 r . . 8 8 8 8 4 0 0 16 16 16 16 0 0 None
0x49 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x4a 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x4b 24 dc 0 32 0 r y . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x4c 24 dc 0 32 0 r y . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x4d 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 2 1 Ncon
0x4e 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 2 1 Ncon
0x4f 24 dc 0 32 0 r . . 8 8 8 0 4 24 0 16 16 16 16 4 1 Ncon
0x50 24 dc 0 32 0 r . . 8 8 8 8 4 24 0 16 16 16 16 4 1 Ncon
0x51 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x52 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x53 24 dc 0 32 0 r y . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x54 24 dc 0 32 0 r y . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
0x55 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 2 1 Ncon
0x56 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 2 1 Ncon
0x57 24 dc 0 32 0 r . . 8 8 8 0 4 24 8 16 16 16 16 4 1 Ncon
0x58 24 dc 0 32 0 r . . 8 8 8 8 4 24 8 16 16 16 16 4 1 Ncon
Anyone got any more suggestions ? :\
PS: This is what gdb reports when maya crashes:
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread -1209128720 (LWP 4075)]
0x034d0991 in GLFunctionTable::populate () from /usr/aw/maya8.0/lib/libHWGL.so
