Ragnar , thank for your help
I freeze the parent and everything is ok in Maya
but when I export it to shockwave 3D , there is an error :
Rotate is animated, but rotate pivot is nonzero. Macromedia Shockwave 3D does not support pivots. The animation may not look the same as in Maya. If you see a problem, either set the pivot to (0,0,0), or introduce another transform in place of the pivot.
I don't understand what it means, could you give me more suggestion?
Thank you
