I know this has been asked a million times but my situation is a bit different. I am trying to compress this for my website. My Demo Reel is 1min 46secs. I rendered it out in Maya as Targa files. This is a modeling reel w/ turntable revolves of the models, wireframe on shaded, no texturing yet.
The uncompressed file rendered out in AFX is 3.44GB @720x540 (this is for my VHS/DVD reel). I then stretched it in AFX to 3 diff resolutions for web using the Quicktime pro Codec (H.264): 360x270 (46.8mb) 320x240 (37mb) 240x180 (24.3mb).
These sizes look great but are much to big for web. I can get them smaller by exporting in QTpro but they look really crappy and you can not make out the wireframe on the models. I have read through the boards and tried other Codecs ect. and i am convinced that the Targa frames are just too big to begin with!1.48mb per frame).
Is there a some way i can adjust the targa files in Photoshop to make them smaller w/o loosing quality?
Is there some setting in AFX that will help?
Or do i need to re-render it out in Maya and adjust something in the Render Globals settings?
Please Help! I have been fussing with this for weeks and my hair is turning grey.
seesh... interesting you get better quality out of mpegs opposed to H.264 or sorenson3. Wich is offcourse insane. Have you ever heard of quality sliders, or bitrate controlls. AND especialy compressing the sound channel as well as the image one.
It not realy uncommon to see pople packing videos where the sound channel is 5 times as wide as the videofeed just because nobody in the compression process whas avare that you needed to compress the audio separately too.
Note the the compression you get fortm afx is the same as you get form qt you jsut use different sluder values thats all. 2 pass compressors like mediacleaner or dr divx are a different thing indeed, tough.
Niiice, although I think that the second character could be rendered better when it comes to the polygon display, as you can see through the mesh. The rest of the reel is good, although you should show some other genres, just to show the HR people, that you are not limited in your style.
QUOTE(dunkelzahn @ 11/22/05, 04:52 AM) Niiice, although I think that the second character could be rendered better when it comes to the polygon display, as you can see through the mesh. The rest of the reel is good, although you should show some other genres, just to show the HR people, that you are not limited in your style. [snapback]220435[/snapback]
thanks for taking a look. I agree about the second character, thats the way the 'wiredata' shader seems to work with polys. If i decide to do it over i'll just do a hardware render (like in the Sub-D model). I am working on other models. I want to get these textured first.
Okay, just found a trick in Maya you might find helpful!
When you render your polys, duplicate your object, scale it slightly smaller (99.999%) and add a shader to the smaller model, where you set the Matte Opacity Mode to "Black hole". When you render the polys you will see that only the polys at the front are rendered, those at the back are blacked out AND you get a correct alpha.
QUOTE(dunkelzahn @ 11/25/05, 07:54 AM) Okay, just found a trick in Maya you might find helpful!
Useful, eh? [snapback]220724[/snapback]
Actually that is the trick i used to render the Sub-D model. Except I did NOT scale it (i wasn't able too and i forget why). Surprisingly it turned out fine.
QUOTE(Joojaa @ 11/25/05, 09:30 AM) move normals instead of scale! Anway for polys and subdivs id just do it with mr contourrendering istead! [snapback]220734[/snapback]
I believe I tried contour-rendering. It looked a bit too 'cartoonish', not good for a hi-res poly model.
QUOTE(shredisdead @ 11/26/05, 05:08 AM) I believe I tried contour-rendering. It looked a bit too 'cartoonish', not good for a hi-res poly model. Robert
okay so you dont want thin aaed aaed lines then, thet show exactly teh same as the wireframe render! but look better? Its doable pretty easily. for much better lines.
IM in abit of a hurry so i cant post demnstration but ist doable allright. all you nee dis to prepare a uv layout that distinguishes each poly form eachother.
