Help to reduce texture artifacts and flicker
Hey there,
We are troubleshooting with texture 'flickering' when the 3d moves/also when the camera moves.
  • Here is the hypergraph network set:
Details : (Blinn) - Mountain as bump map, fractal and ramp for color, moutain texture and custom texture for displacement.
  • Here is the mental ray details/No final gathering:
  • Download video file here (1.6 mb, mpeg - right click and save as).
  • There is an ambient light and directional light for shadows in the scene.
    Any help/advice would be very much appreciated.
We have two more weeks to nail this!:wink:
Thanks and take care,
J
Do you have a texture reference object to freeze the 3d texture?
  Anywayyou have  a second problem too and that is that your exceeding the Nyquist limit with your frequency*. You should lower the frequency of your procedural texture by distance from camera. AA contrast wont really help, since your frequency is so insane. And here also a small preview does significantly worse than final size images since the recostruction of the image is better with higher resolution.
What Nyquist limit essentially says is that if your detail frequency is smaller than one sample distance (in other wods 1 pixel which is your initial sample) then the image can not be coherently rebuilt and it leads to aliasing. AA does only lower the sample size but because its adaptive its going to guess wrong. Its actually easier to just ask for a suitable frequency, and then drop frequencies as you go further away.
If you don't want to fight with the technical stuff then just bake it to a texture as its easy to filter right. Thats what many outfits do when they don't want to pay for a TD to actually look at the stuff, its inferior in some ways but easiest to implement.
*the thing is its looking good for still images but this is a sort of a do or die thing, you either get high frequency and aliasing OR you get filrtered stuff and no aliasing. They are tradeoffs, you cant get both at the same time.
No, I don't but I did try this method. I also tried the convert textures to files method but the frequency still exceeds the Nyquist limit it seems.
This is what it looks like with no displacement or bump map. With a simple color work in photoshop and that renders very nicely.
Download the cartoon video demo as a gift to you : here
We're basicly looking for a way to get some crispy details on the texture /or the model itself.
Do you have any suggestions/advice on how to give this a crispy look ? Because if we just use the actual 2d image of it it looks very ugly. Any help would be very much appreciated.
Thanks a million.
J
Duplicate out your object and bump material..
then in a new scene, import the object and material, and apply the bump to a new shader. Then select your object, and go to hypershader and add-select the shader and then go
Hypershade > Edit > Convert to File Texture (in the options choose a larger map, say 1024 or 2048 and an image type of your preference)
That will spit out a non procedural bump map that is visually close to the once you've been using but more static looking.
Then just go back into your main scene, break connections with your old bumpmap and use the one your created in its place.
Thanks for the tips.
For the bump map its works well when converted to a file texture map. But, the displacement map filters so much of the details as a result it looks very bad.
This is an image of the 3D character with the procedural shader (and not the file textures, well, only for the color).
Is there another way in your opinion to achieve such displacement result by using a different technique?
I tried to modify the displacement to polygons and that doesn't really work for us.
Maybe by using the rockGen script and placing tiny rocks all over the head. Will give that a try.
:slight_smile:
J
