I am writing my first mel with 2 proc
global proc A
float $abc = 1;
global proc B
float $def = abc;
so I got abc is undeclared variable
I could not understand why
Could anyone help me
global proc A
float $abc = 1;
global proc B
float $def = abc;
something called scope do a search for it in the docs...
The variable $abc ONLY exists inside proc A (and ONLY inside the { } it is defined between), so when you reference it inside proc B, proc B has no idea what it is. (i'll assume all your other syntax errors are just cos it's pseudo code!
if you DID want this to work exactly as is, you'd have to declare $abc as a GLOBAL float.. but global vars are not really advised...
:nathaN
