Help with connecting NURBS
Ok, first time posting here. What I'm trying to do is make a club(the card suite). This is what i have so far. I know it's messy right now, but the plan is to convert it to polygons and smooth it out. However, my problem is, how the hell do I connect these three "leaves." I've tried a bunch of different things, and I'm totally lost...
Any help would be much appreciated, thanks ahead of time!
Best Regards,
Chris
Well, 26 views and no replies? Did I do something wrong? lol...
If you intend to convert to polys later anyway why not model it with polys from the start. It will take only minutes this way (see this image for workflow.. club ). Give it a shot . You can also skip the subD and go straight to smooth and also if you want nurbs you can convert the subD model. If you want the wire file let me know.
If you still want it to build it in nurbs then you can build the center piece first, including the stalk and then use blend surface to join the two side leaves. You can see from the SubD model how this can be done with nurbs. Also try to make the skins one complete surface. In your model it is broken up in to many sections.
Good luck.
THANK YOU VERY MUCH!
At first I didn't really get what you were saying. But, I spent a little time playing around and I finally developed a clean model, well, clean enough for what I'm using it for.
Take a look
If you can't tell, I am VERY new to this. Although this project worked out great for me, I still don't quite grasp the correct thought process for creating an object. Like, nurbs or polys, and the correct, most effecient way to do it.
Does anyone have or know of any basic, beginner tutorials or lessons on how to go about modeling objects in the proper most effecient way, and how one makes the correct decision on which tools/methods to use for which type of projects.
Once again, thank you very much for your post.
Glad to see it worked out for you.
You can check out www.learning-maya.com which is a fairly good resource for tutorials (basic & advanced).
As a rule of thumb in the world at general theres no such thing as MOST EFFICENT, or BEST. Ita a optimization issue! I maen you got something you loose something. So what you need to do is fmiliarize yourself with dos and donts and workflows, then decide ona cas by case basis whats the best way to go about your thing!
