I had a similar problem with moving a large graphic through the frame that had edge rays applied. Only seemed to be a problem when rendering with fields. The way I cured it was to put a viewport (same dimensions as the final output) in the tree before you add the Sapphire plug-in node.
Hope that helps
Peter Wiggins
Come & say hello on the Grass Valley Stand at NAB!
