I 've never used After Effects and although I went through the help section I didn't find the answer to what I 'm looking for. I 'm planning a black and white video in which the only color used is going to be a pair of red shoes that the main character is going to wear. How am I going to materialize this idea? Do I have to just use masks? If so, how am I going to do this?
well, there are a few ways to do this. The first is good old fashion Rotoscoping. Export your video into an image sequence and edit out all the color except the shoes frame by frame. This is long and tedious but gives maximum control.
A much easer/faster way, would be to import your footage to after effects, and use: Effect>Color Correction>Leave color. This method may glitch out quite abit if your lighting isn't perfect.
I havn't gotten good results with this yet, but you could screw around with: Effects>Keying>Extract. Set the channel to Red and play with the black/white points. I'm only mentioning this because I havn't played with it alot and maybe with some luck you'll have better results than I.
The last method, and supposivly the best, would be to buy the plugin "Silhouette Roto." I havn't used it, so I can't say how well it works but it's a program made to use motion tracking on masks. This would be your best option if you have the money.
if i may add one more suggestion, a simple colour key and a desat should work to (as opposed to a extract key). but the leave colour is probably the easiest.
