Hi (4)
Im new studio user , but im in this job almoust 6 years
Will you see my site and tell me what you think about ..........
Also i want comments how can i use Pro/Engineer and Alias Studia 9.5 , becouse
i `m not to familiar with working with Iges files in ProE.
When i import File from Studio (one part or ... ) i get ? What.
I realy don have to much expirience with iges geometry wich cam back in ProE.
I have only export files , but what now.
Do i have oportunitu to conect Studio & ProE that they work good.If
Someone want to help me , i will explain my Problems
I want to work on one project
I must mak mechanizm in ProE , And i must make some part in Studio.How can i continue to work on this
files in ProE
Maybe my idea of work is not good , but tell me how can i work something like thet.
Problem which i don mention that i must conect mechanizm with part from Studio.
Look my site , and in case of Sn you will see what i want to do.
Project which i start to wokr today , and Sn is not same , but todays project will help me
in case of SN becouse sn will be again projected (redizajn) and i want to uyse some
oportunities from studio.
For now that is all.
I know that i have many mistakes in speling , but why they call me spelingmistakes )))))))))))))
Upssssssssssssss This is my site
http://solair.eunet.yu/~doce/
Salute From Speling
hey speling,
I haven't worked much with Pro-E, but with I-deas (basically the same) there is generally no problem with importing a surface, then using it as normal data. (i.e offsetting, rounding, making solid etc) Of course you lose the construction history from Alias, but this isn't usually a problem as long as you have the design surfaces finalised in Alias. One hint though - try to do the rounding in the solid modelling programme - trying to offset/solid rounds done in Alias will cause you problems...
chris
p.s - try posting to the Studio forum next time - you'll probably find a more sympathetic ear there
