Hi And Low Res Binding
I have created a character using the CPS plugin in Maya.
I deleted the high res when I was finished and I have bound the low res to the skelelton and painted weights and added blend shapes to it. I am not sure what to do now.
Can I duplicate the low res (with input connections), smooth it , and put it on a seperate layer to get a high res version?
Is this the proper work flow when creating characters using the cps tool?
no need just run a smooth proxy on it! maya tehn differentiates histry so they share the same tree. and you now have onbe highress thats bound to the lowress.
In general there snothing worth isntalling in cps if you exclude the panels wich in them selevs are realy easy to build.
so are you telling me to just smooth my low res version? don't i need to keep a low res version for animating and a high res version for rendering (on a seperate layer)?
this leads me to another question: do I uv texture the low res or high res?
thanks a lot for the quick help Joojaa!
QUOTE(Joojaa @ 09/27/05, 03:30 PM)
[snapback]215776[/snapback]
also, I have noticed that the vertices on the smoothed high res have no weights painted to them and yet when i open and close my characters jaw the smoothed verts move beautifully because I painted the weights on the low res before I smoothed it.
I guess what I am asking for is reassurance that this process is sound and won't F up when I go to animate!
thanks again
No im saying use smooth proxy ista bit different (it makes you a nice3 tobble between the resses etc but basicaly just a covinience tool). but smoothing works equaly well but you might want to use smooth prxy for ease of animation.
Se whats going on is history! you allready animated/bound that state that will be smoothed in the future! the old lowres is still intact yet hidden as pert of the history open hypershade and graphi to looksee.
ooohhh! so you are saying use a smooth proxy and just put the high res on one layer and the low res on another so I can toggle between them right!?
thanks for the helping the newbie joojaa
smooth prxoy can take care of that for you just chek the box for smootproxy creation and youll se loads of optiona about this and that. jsut chal the smoothproxy layer and smooth mesh layer and you are set,
