Hello, I’m having trouble with baking ambient occlusion from high-poly to low-poly object (#2 on the picture below). I’ve managed to bake normal maps perfectly from this set-up (#3 and #4) previously, however with AO I have some vague problem. The thing is it barely bakes anything, just a little outline is visible (#4). I’ve tried changing envelope (#5), it gave some results, but still not something you’d be satisfied with. UV maps are unwrapped, and not overlaying (#2). At #1 you can see all the settings, I’ve set them while following an AO baking tutorial. I’ve tried diffrent settings without any results, though. I’ve also set the render quality to production, just in case. So, any ideas?
A cylinder shape like that wouldt actually have much of an occlusion at all to begin with and in this case when transfered even less since most of the occllusion is perpendicular to the shape.
You may actually be right. I didn’t think that edges being too soft to produce occlusion. So how can I produce a really nice layer of object’s depth for my texture to paint? I need thihs to make a lid for a canister. Any ideas? Maybe I should bake something else?
Nevermind, I’ve hardened all the edges, and occlusion turnd out to be just what I wanted! Thanks Joojaa for your help, your advice has led me on the right path, really thank you!
