High Fluid Resolution Problem In Maya 2009
I'm not quite sure it's my computer problem or maya version problem.
I simply created a 3D fluid with resolution 100*100*100 in maya 8.5 and cached. Even the cache file is huge but it worked.
However when I tried to do the same thing in Maya 2009, Maya just crashed immediately while I was creating fluid cache.
Is it a bug in Maya 2009?
In a way. I would say it's a performance regression and yes, you should log a bug with Autodesk.
is it the same file? the cache was re-written from 8.5 to 2009. I did that test before on my computer and have no issues at all at that rez or higher.
Yes you have to redo the cahce.
