http://www.theinquirer.net/16040206.htm
i thought it was the other way around, with AMDs being faster modellers and slower at rendering. argh i can’t decide which to buy! ![]()
That’s cuz the video cards are specifically optimized for the P4s as opposed to AMD. (Go figure…MORE optimization for P4 to compensate for P4s crappiness.)
read this: http://www.theinquirer.net/16040206.htm
Actually no the Nvidia drivers are not at fault. Do not ask much more, but what I can tell you is that there is a complete problem across all the chipset range which is being looking into very hurriedly by AMD, SIS and VIA. If you note the article properly they say at the end ’ we suspect that there may be some underlying reason which we’re trying to figure out’
We have not been able to run any of the cards on the Dual Athlon’s at all. If you note we haven’t even posted back return results on the Wildcat III 6110 or 6210 (these have optimised AMD drivers). Its not one or 2 cards that will not run on these boards but all of them.
along the lines of this topic, where does the Xeon fit in all of this..? i read a review where dual AMDs kicked 2 Xeon 1.7s arses, but that prbly doesn’t mean much, all the procs seem to be overtaking each other all the time.
Does the Xeon have anything which makes it especially powerful with interactive modelling, and how is its FPU (for rendering)…? what is the cache on the Xeons like…
the new MIPS procs look pretty beastie with 4MB L2 cache :-)))) not that i’ll b getting another SGI for a while…
At high end processing (cloth solving, heavy paint effects, dense Sub-d scenes - Heavy scenes) Xeon performs better - it optimizes memory way better then AMD.
On light scenes AMD’s FPU takes over Xeon
Xeons are much more stable - specially in video prod - if you let’s say working with DC2000 or so.
More stability - more pro use…
AMD’s are great Chips, but for professional market you need speed, system stability and compatibility - AMD got just one of this - speed.
$1000 difference between AMD and Xeon System, doesn’t mean much in pro studio.
Xeons are great chips - for pros - gamers should stick with AMD’s
The reason the video cards are faster on intel box’s is because intel’s implementation of AGP is somewhat superior to Via’s, AMD’s or SiS’s. As far as AMD cpu’s not being as stable as or compatible with intel variants; they are very much as solid. The only real difference is that AMD CPU’s currently run hotter than the intel counterparts. Things that often cast AMD in a bad light are the alternate chipsets on the motherboard. SiS is a good example. A p4 in an SiS board is just as unstable as an athlon in an SiS board. Via seems to be doing better though. nvidia’s 420 chipset is pretty solid too.
Naturally Intel’s 800 series chipsets are rock solid but p4 only. Though currently intel is pushing hyperthreading which could make or break it as a performance leader in the workstation market.
