in my workspace panel, it doesnt show the camera or the lights, or if you do a paint layer and do some text it doesnt show the text operator under the paint in the heirarchy......so basically it looks like the heirarchy has been collapsed......and it was fine till yesterday then all of a sudden i think i did something and they dissapeared....ive tried the preferences, but if you know what it is i could have missed it.
There's a little "triangle" in the upper right corner of the WorkSpace Menu... It looks like " >"
Open that up and you'll see that you can specify WHAT elements you see in that panel.. You probably changed a setting without realizing it...
If you ever get screwed up again, remember that you can SAVE ALL, and close combustion.... Then, do a search and find the file called "host.ini".... That is the set-up preferences for Combustion... Delete it, and then just open C again The file will be re-written using ALL FACTORY DEFAULTS..
Open your CWS, set your Preferences again, SAVE ALL, and get back to work!
