Im in the process of evaluating Houdini version 4 on the NT platform, an Im trying to get the RenderDotC 3.1 demo to work. In Houdini ver 4 there is a option in outputs to to use RenderDotC 3.1 but it uses the command "render". RenderDotC uses the the command "renderdc". I tried replacing the command but no dice. I checked all my environment variables and it all checks ok. I also set houdini to the renderdotc demos restricted resolution and still no dice. Even though Im using the the renderDotC 3.1 demo it shoud still work under it's restricted resolution. Am I missing somthing?
