How Can I Export In Shake?
hello . i am an amateur shake user and i need help for export my composite in shake . befor this i use after effects and now i want to use shake for composite . how can i export (batch or sigle frame) in shake 2.5. merci .
QUOTE(gilbert @ 12/05/05, 01:52 PM)
[snapback]221606[/snapback]
under image->fileOut then on top click render->render file out nodes. make sure you specify your range as follows 1-100 gives you batch of 100 images. if you want specific images type ie. 5,16,80 etc.
Also get friendly with the manual its a great resource for most of the questions you might have.
Michal
Also use a # sign to designate a frame number else shake will render over your output images so you will get one image. This is found in the FileOut node.
Exa.
jaja.###.tif
In the save image dialogue.
special thanks for your guidance . now i can export in shake an practice it .
you can also do a movie file w/ 2.5 for windows, if you are using linux u can't do quicktimes
so u could do name.mov or you can do an iff sequence which is native to shake. like name.@@@.iff it is always good habit to make the same amount of #'s or @'s as the decimal places of the render for instance 50 frames would be name.@@.iff and 100 frames would be name.@@@.iff 1000 frames would be name.@@@@.iff This will give you 0001, 0002 for you sequence names.
Funny that the manual doesnt cover this issue. You should probably inform Apple of this omission.
