I'm using a PoLy Cube, and It's moving around the scene. I need to know if it intersects with any other Nurbs surfaces, or Polygons that are placed around the scene. If there is in fact an intersection, I need the names of those geometries that intersect with the Poly Cube.
It's a toughie... no simple mel script is going to return the information I require, so it's up to you advanced MEL scripters to help me out if you would be so kind.
thanks,
