how can i reverse clip and pingpong clip in ae and premiere.
In AE you can use time remapping and keyframe the time of the clip to go back and forth.
I'm not that familiar with Premeire ..you have have to make seperate clips and reverse one. I kno wit has a clip speed control somewhere.. look in the manaul
enable time stretch in After Effects, Go>Layer>Time Stretch, enter -100 for reverse, and same goes for premiere, press Ctrl + Shift + R for speed, or go Clip>Speed then enter -100.laterz...:B
short cut in after effects to reverse a clip is ctrl + altr + Rwhen you do that you should be able to see some red lines on the layer that mean its in reverse form...all the best
inAE, you can use expressions, and i think this is the best way.loopOut(type = "cycle", numKeyframes = 0)
then replace cycle (wich the default exp) by continue or pingpongyou can find the expression in the "property" expressions
jiheli
or enable time remapping and copy paste the in and out keyframes along all the sequence
Error: Backend Fetch Failure
