I have made some animation where I have need to re-create the glow of Maya in AE.
I found that Maya glow is very nice, but i can't use it for some technical reasons. In AE, glow is not vey fun.... may be some one know a way, (special settings, special stack or filter, or external filter) to get this effect...
There are virtually hundreds of techniques to create glows. Here are some tips:
The AE Glow filter is suitable only for 'quick and dirty' glows. It basically does this:
Take alpha of layer spread or choke alpha blur alpha colorize composite behind original layer
By creating the effect implicitly instead of using the canned filter you can get all sorts of effects. For instance if you want animated streaks of sorts, you could take the alpha, matt it with another interesting b&w layer, apply a directional blur, levels, and then perterbate that with another moving b&w image and comp it with a transfer function to a solid.
Using this basic theme, you can create hundreds of glows that have never been seen before. Good luck.
