make 3 testures
1 corroded
1 black and white how to animate corrosion ramp
1 noncorroded
make blend node
connect coorroder in slot 1 and noncorroded in slot 2 then connect the bw corrosion ramp trough a set range node to the blender attribute and then key the ramps min max values to move form one extreme 0 to the other 1 with a slight gap between min max (say max is min + 0.05)
