How do I change the mel editor
Hi. Can anyone tell me how to make, let's say ultraedit, the defult mel editor?
The way I have done this in the past is to make a shelf button that references the MEL script that I'm editting in Ultredit and just click after I've saved changes in Ultraedit
file -i "C:/Documents and Settings/Administrator/My Documents/maya/scripts/testscript.mel";
Well I need it mostly because I'm creating runtime & creation expressions for particle systems. Does maya save these to files?
Supposedly you can set the expression editor to use an external text editor. When you choose text editor in the expressions window it is uspposed to launch the text editor that in windows you have assinged to .txt files.
I cannot get this to work??? Supposedly when it does work it does save the expression to a temp file.
file://C:AWMaya4.0docsen_UShtmlUserGuideExpressExpressEdit4.html
Thx, it's working now. I made it work by changing to the text editor in the "Window" >> "Settings/Preferences" >> "Preferences" window. I can't make it work if I just change it in the maya script editor... Maybe that's what you're doing wrong.
Huh.. yeah that works.. according to the docs it should work in the expression editor if you choose text editor??
