How do I "cut" a NURBS surface?
Hi all,
I am just getting started with Maya and am going through a NURBS character-building tutorial that tells me to "cut the head in half in the middle." So I projected a line down the center and trimmed the surface.
However, the tutorial then had me copy the side of the face and invert it so that I could attach the two sides together using Blend. When I attempted this, I received an error telling me that trimmed surfaces cannot be attached.
Since the trim didn't work, I considered cutting the head in half with the detach surfaces feature, but the surface does not lend itself to generating an isoparm in the appropriate location (the isoparms cross the center of the head).
Am I doing something wrong, or is there another method of "cutting" that I'm not aware of? I'm at a loss, so any suggestions would be greatly appreciated. Thanks!
trim is not equal to cut! Use select isoparams and detach instead.
Trim does not realy do anything to your modell except to hide the trimmed part. As such it cant be attached because it breaks the rules on how nurbs work.
You should realy read nurbs modelling theory more before you start doing this or then adhere to the tutorial to the letter.
well there are a feqw tricl syou could do but youd probably like them like milk likes lemon.
Can you post a link to the modeling tutorial you are using, ovni?
Thanks,
CG
Cool, I'll try out your suggestion. Thanks for the advice and clarification!
I'm actually following a tutorial from the Mastering Maya 3 book (bought it several years back, never had time to go through it...).
