In Max if I invert the normal of a polygon the face flips the orientation. Like I want to make a room from a box. I create a box then I flip the normals.
Yet, I don't understand what is the normal flipping in maya does.
If i invert the normals (I can see they are inverted) but the poly orientation stays the same.
Select the faces in component mode a and choose flip normals. Note thet maya anctualy has normals for faces and or vertices a bit depending on the geometry!
Ok, i see i needed to turn on the back face culling. But I still have a question that is driving me crazy.
I now have the backface turn on, so the poly's aren't double sided.
Yet, if make a plane and position my camera on the top and press the IPR render button (render the current frame) it renders the surface. But if I fly behind it doesn't. Regardless what is the orientation of the normals. If I flip I get the same result from the two views of the camera. It sounds like the IPR is ignoring the normal orientation.
Go to disply>polygon components>normals to give yourself a graphic representation of the normals. Make sure you have your object selected before you do this.
The only thing that I see is that when you do an ipr render, the default light does not get deleted. Make sure that you have a light to illuminate the bottom of the plane.
