I can only run Maya as root. How do I change this?
This should be the same no matter what distribution you are using, right?
Right… In theory, doesn’t always work that way without a little encouragement though.
Some more information could be helpful. What happens when you try to run it as a normal user?
- Gef
Seems like a simple chown command on the flexlm dir did the trick! ![]()
