How do you add a control vertex to nurbs curve in a specific spot as apposed to using rebuild curve?
Thanks
right click the curve and select curve point.click on the curve once where you want the new CV to be. a yellow dot should appear.with the yellow dot still there, go to edit curves>> insert knot.
Error: Backend Fetch Failure
