How Do You Create A Luma Matte?
Is there a way to use a grayscale image as a layer mask for another image. I know you can do wierd things with select>color range but that isn't what I want. I want to be able to take an image, desaturate it, and use it as a mask as is in a layer mask. I've seen it done but I can't seem to figure it out.
select desaturated image, copy to clipboard, then add to main layer a mask, select it, go to channels, select mask channel and paste from clipboard stored grayscale.
Hmm. For some reason, that isn't working for me. I'm following every step exactly, but when I got to copy the desaturated image from the clipboard into the the mask layer under channels, it just pastes the desaturated image as a new layer. I doesn't paste it into any of the channels.
nevermind, I figured it out, I had to make the mask layer "visible". Thanks for the explanation.
