Perhaps you could check in the attribute editor under Dynamic Properties then under Dynamic Properties Maps and then put in a grayscale texture map, saying where it needs to be rigid and where not. Having it be rigid in the flat areas, but not rigd on the seams.
I don't know if black or white is stiff. But it should be easy to check, and a simple invert will change the values back.
