I’m trying to get my head around texturing a polygon character, i can texture other stuff fine but can’t seem to figure out how to do a complex piece of geometry like a character? is it essential to use the uv texture editor or are there other ways? do you just select parts of the character and just apply different textures to different faces or is that impractical with a character as they are always square? any help would be appreciated…
Your question is VERY BROAD.
In fact imagine all you know about modeling, getting the shape for the character. Now imagine how much such knowledge there is outside your knowledge. In other words lets say multiply what you know by 10.
Now textured is as broad a subject as the entire field of modeling, just however usually considered harder than modeling especially because to get modeling going one usually skips the part where you design at modelling stage how the uvs are going to react, making uv mapping unnecessarily hard
Wait 3 years then you dont need to layout uv’s, your not the ONLY person who curses texture coordinates to the lowest pits of hell. Almost everybody does including Disney.
yes you need to uv map, you can also try to work blind if you wish. But yes there are other ways tough not necceserilily available for you, since that would mean you would need to forego using normal 2d textures and use something like Ptex.
http://www.disneyanimation.com/library/ptex/
Now this contains two assumptions. Yes textures are always square however they dont have to cover a sqyuare area. That’s why you lay out uv’s.
ok maybe this will be easier if i post a screenshot, you see i’ve just modelled a polygon biped, i know not the best in the world but i would like to have a go at texturing it, problem is when i go to uv texture editor i get this jumble of uvs and don’t know where to start???
this site has a basic tutrial
To lay out you UVs neatly and intuitively you will have conceptually break your model into parts - arms legs, front n back torsdo, ect and spend a lot of time selecting different parts (faces) and creating UVs for them.
for example you can select the leg faces for 1 leg, create cylinderical UV map and get a result in the UV editor that looks somethign like an unwraped leg…Faces and torso you can map with a planar map.
One tip: before you map a new part, go to the UV editor, select all the Uvs you just made, and place them outside of the main square area. That way, the next part’s UVs won’t be overlapping as they are in your screenshot. When all the parts are mapped, you can select the uvs and move them into teh main square to arrange as needed.
UV mapping takes time to wrap your head around, and a lot of iteration to get bthe mapping right. be patient and keep tryin.
thanks alot for that!
also, the first 19 pages of this
http://www.unwrella.com/files/unwrella\_maya\_tutorial.pdf
pages 20 and beyond are for a special plug in, but the first bit has a good, universal workflow example.
another thing: Maya supports multiple UV maps for objects, but this only confused me when I was learning. Ignore multiple UV maps until you get a grasp for layign it all out on one UV map.
thanks mate!
