How Do You Mirror The Cut Faces Tool?
Is there a way to use the cut faces tool and have that same cut mirror in the opposite axis? thanks
If you are working on a half of the model and the other half has to be identical, you should make an instance. Go to duplicate options and select instance, that’s it.
Im not sure if this is what Im looking for. Maybe it is, but Im just not understanding. I know creating an instance cuts down on render time etc., but I dont understand how creating and instance would help me reflect the cut faces tool in the other axis?
Let me explain more what Im trying to do. I know theres another way to go about it. Basically if I can use a polygon shape as a cookie cutter type tool, that would be perfect. I need to have a rectangle cutout on the face of one of my shapes. I also need to have a hemisphere cutout on one of the faces as well. I remember reading about using another shape as sort of a cookie cutter tool to make unique cutouts in certain shapes. Does this only work for nurbs?
QUOTE
I dont mean the particle instance thing…
It has nothing to do with rendering, it’s just a copy of your model. When you deform the original model, the instanced copy will deform as well. so if you have a half of your model you can duplicate it and scale it to -1 in some direction (it will become the other side, mirror effect) you will have two sides of the same model but you will only need to edit one, and the other will deform accordingly, resulting ion perfectly symmetrical model.
Yes, there is “cookie cutter” tool, they’re called booleans, but i advice you to not use them because they cause lots of trouble. Joojaa explained it in some earlier post…i’ts quite complicated, not sure i get it so i will not try to repeat it, the point is…avoid it. Tough to face it but you should do it manually, if you use nurbs then yes, its much easier then polygons. But you convert forth and back .
Ok thanks! That helped alot. I made an instance, scaled it across the axis and all worked great. Heres my next problem. I am working with a polygon here and its basically just a rectangle with some shaping to it. I need to now make some sort of circular cutout in part of this polygon. Is this possible? I know booleans cant be used since its a poly, but is there another way to do this instead of rebuilding it with a nurb cube?
