How do you turn off the local rotaional axis????
when rigging?
Huh? Does not compute. Theres no other kind of rotation than local. Rest are just groupped illusions.
Are you possibly referring to turning off the visibility of the local rotation axis? If so...select the object whose local rotation axis you want to hide, then go to (in the main menu) Display -> Transform Display -> Local Rotation Axes.
Do you mean that you want to change the settings on the rotate tool? You can switch between local, global, etc for the various transform tools if you go to the tool settings box. Or you can use the marking menus.
It's not just for rigging, obviously. You use it for modeling and animating just as often, but I don't know what else you mean by "turn off the local axis."
This is what I'm talking about - http://www.setdrivenkey.com/2008/06/tip-of...hink-local.html
Go to “show” on panel menu then uncheck “handles”
Yes , That’s it ! I wish I could create a button to show and unshow them.
