I tried to attach an icon to a buttonManip, but was unsuccessful. Does this feature work for anyone? Also, does anyone here use buttonManip manipulators?
Thanks for any info,
Michael Duffy
mduffy@dnahelix.com
Michael Duffy
mduffy@dnahelix.com
I used buttonManips for a while, but in general, I stay away from them. They seem like a good idea, but keep a few things in mind:
1. The buttonManip icon (or icon file) won't scale with the camera, so as you pull out, you'll get a big glob of buttonmanips that are hard to select.
2. They're "touchy". From my experiece, if you select the ButtonManip in the outliner, and translate/rotate/or scale it, it'll break.
3. If you reposition the buttonmanip using it's triad, when you re-open your scene, the buttonmanip will have jumped to it's original position.
4. While you can load images as the button, people have reported this crashing Maya. Not to mention you need to pass these files off to anyone else who uses the scene.
I did get the custom icons to work, with the -i flag, but I'm not sure how (it was a long time ago). I presume you save your image as a .bmp or .iff, and stick it in your sourceimags, or textures directory, and it'll find it. They seem cool, but those big blue buttons can just get in the way after while...
I am just starting using them. They seem to be a good idea indeed. I don't hope that I will have these break problems described below.
In order to load an icon you can do the following:
use the -i "path/iconname.iff or bmp" flag. You can also change/add them afterwards by selecting them in the outliner/hypergraph and enter the icon path/iconname combination using the attribute Editor. That should answer your question.
But I have another question regarding Button Manipulators.
Is it possible to have transparancy on these images? I tried alpha channles and the green colour which is used for Layouts. But none of them work. I also wonder what kind of method AW uses for Cluster icons or grid numbers?
Cheers
HumHum
