How To Animate Stabilization On & Off
Hi-
this is probably very simple.
I'm am using a stablize node to smooth out a portion of some helicopter footage(IMAX).
Most of the footage looks good and then becomes shake say 3/4 into the live action plate.
I don't want to suppress the beginning footage because it feels good, but I would like to dissolve the stabilization math on near the problem area and then back off again.
I would like to use another "dummy event" to control that "animating dissolve curve".
thanks for any advice.
PR
GOT IT!!, created local expression in stabilize node
Just use a select node to go between it off and on.
QUOTE(beaker @ 11/06/05, 11:29 PM)
[snapback]219011[/snapback]
How can I "Dissolve" over say 20 frames with a select node, the select node is a switch (no?) that I can animate with, by default it uses a step curve (i tried changing it to a linear curve, no go).
What I wnat to do is take the expression that drives the stabilize and mutiply that a curve that animates a value from 1.0 to 0.0.
I have created a local variable in the stabilize event called "multiplier" which is an animated linear curve. I have taken the expression in the applyX.xShift and added my local variable "multiplier" to it like so, it looks like this in the xShift string:
track1X-(track1X@@refFrame)+((track2X-(track2X@@refFrame))-(track1X-(track1X@@refFrame)))/2.f
I take this and modify it so:
(track1X-(track1X@@refFrame)+((track2X-(track2X@@refFrame))-(track1X-(track1X@@refFrame)))/2.f)*(multiplier)
and as long as I don't close the parameters for the stabilize node the string stay's there as I modified, it gives me the result as well, I can even render a flip of the result.
but if I close the node parameters and reopen them up again, the modified expression is gone.
I'm screwing up on the syntax somehow (obviously not a scripter)
hey, here is a script that is illustrates the problem:
// Shake v4.00.0607 - © Apple Computer, Inc. 1998-2005. All Rights Reserved.
// Apple, the Apple logo and Shake are trademarks of Apple Computer, Inc., registered in the U.S. and other countries.
SetTimeRange("1-73");
SetFieldRendering(0);
SetFps(24);
SetMotionBlur(1, 1, 0);
SetQuality(1);
SetUseProxy("Base");
SetProxyFilter("default");
SetPixelScale(1, 1);
SetUseProxyOnMissing(1);
SetDefaultWidth(720);
SetDefaultHeight(486);
SetDefaultBytes(1);
SetDefaultAspect(1);
SetDefaultViewerAspect(1);
SetMacroCheck(1);
SetTimecodeMode("24 FPS");
DefineProxyPath("No_Precomputed_Proxy", 1, 1, -1, "Auto", -1, 0, 0, "",1);
DefineProxyPath("No_Precomputed_Proxy", 0.5, 1, 1, "Auto", 0, 0, 1, "");
DefineProxyPath("No_Precomputed_Proxy", 0.25, 1, 1, "Auto", 0, 0, 2, "");
DefineProxyPath("No_Precomputed_Proxy", 0.1, 1, 1, "Auto", 0, 0, 3, "");
SetAudio("100W@E0000qFdsuHW962Dl9BOW0mWa06w7mCJ000000000008");
// Input nodes
Double_targets = SFileIn("/Volumes/Homunculus/MWD_related/Shake_Related/STB_dissolve_test/Double_targets.1-73#.rla",
"Auto", 0, 0, "v1.1", "0", "");
RotoShape2 = RotoShape(720, 486, 1, "v3.01", Hermite(0,[0,0,0]@1),
Hermite(0,[0,0,0]@1), Hermite(0,[0,0,0]@1), 1, Hermite(0,[1,0,0]@1),
Hermite(0,[1,0,0]@1), Hermite(0,[360,0,0]@1), Hermite(0,[243,0,0]@1),
0, 0.5, 0, 384, "100W@OK000VDhsuH9RYbMXJCo8QUPcJkW66fOeA6QZYJMQdL5aCgWm8xCNnOpCHnmbHY2P0d6P55Ke2eO4WcQeX2reUP6O0X2Pef9UPQQw#caVHMk5bVV#DdZYJ5fVELMgQQEUcQgH2QgW1fdWa0QZEMOGaQ0QWQlONw93tSJAcAGtgaWwzfRTo05KMwUN4CCf5NVQ6nmk2TZT9Q3ScThf6RiXHMQXUen6vbvXcgd5f4QffeUcPXN5aQcnvMQeNgHMOYUo1J21B8nC2g44RmIRYGBDRmk219Rm16OuW0DWu03Cx0pDpujbci@UWiJ01bQn#xaSohvTTZO1zu8ohZ0aElZtBJcUx9tnfAxEc@MUqfU#yQPEiAdfEWVmxabOopgpv#TvVhb8NpfuhUywAJYMlk@JA#U#Ey8fHnGhQsTGDvESJgUVb9WluMpfuTiQdruUJvoh@CEQzFZWSwcV7aHU67OYSzfzais8pOvGmb1CjGD08300WPS00000000003:",
"100W@SK000VDhsuH9RYbMXJCo8QUPcJkW66fOeA6QZYJMQdL5aCgWm8xCNnOpCHnmbHY2P0d6P55Ke2eO4WcQeX2reUP6O0X2Pef9UPQQw#caVHMk5bVV#DdZYJ5fVELMgQQEUcQgH2QgW1fdWa0QZEMOGaQ0QWQlONw93tSJAcAGtgaWwzfRTo05KMwUN4CCf5NVQ6nmk2TZT9Q3ScThb6OiXnMOfUeX6vbn1cfdHH4PgPeHMQYNb6QXUNcGa5gU6RWPeaHibICZWwQ0reKBlq81nY9Ev8C6il006Si16EBG382ZnFGEPTk6lmOpx@SaJu1W@w7nTSNYdmLGUZO8#NxpZpl#SMWBkCPZUQNTz#wasGpEVvxyXTg79bBb1ypwSVpvJce#td8tBj2sIME6EBVkhwyTz@Z1vIi711oQMcrTXUosFqSgTMkSSmnNP@Y8X9ZElV7@sJbuviP@OQSzSuYy2jwi0onLYyC63Fc9@1M0mWHcBmD00000j00000C7");
Text2 = Text(720, 486, 1, "++++++\n++++++\n++++++", "Utopia Regular",
100, xFontScale/GetDefaultAspect(), 1, width/2, height/2,
0, 2, 2, 1, 0.3440679, 0.13166827, 0.4, 0, 0, -10, 45, 0,
1);
// Processing nodes
Move2D2 = Move2D(RotoShape2, Hermite(0,[-1.6187,-0.01,-0.01]@1,[-1.6213,0,0]@21,[-1.6213,0,0]@35,[-1.6212,0,0]@45,[-0.0003,0,0]@62,[-1.6203,-9.31,-9.31]@73),
Hermite(0,[3.2394,10.22,10.22]@1,[6.4781,0,0]@21,[6.4781,0,0]@35,[5.8938,0,0]@45,[9.9543,0,0]@62,[1.619,-41.28,-41.28]@73),
Hermite(0,[10.1474,-42.86,-42.86]@1,[-5.8019,0,0]@21,[-1.5898,4.65,4.65]@35,[-1.1733,4.83,4.83]@45,[6.2389,0,0]@62,[-8.3394,-58.85,-58.85]@73),
1, Hermite(0,[1.048,-0.34,-0.34]@1,[0.9407,0,0]@21,[1,0.32,0.32]@35,[1.0632,0,0]@45,[0.9497,0,0]@62,[1,0.29,0.29]@73),
0, 0, Hermite(0,[360,0,0]@1,[360,0,0]@21,[360,0,0]@35,[360,0,0]@45,[360,0,0]@62,[360,0,0]@73),
Hermite(0,[243,0,0]@1,[243,0,0]@21,[243,0,0]@35,[243,0,0]@45,[243,0,0]@62,[243,0,0]@73),
"default", xFilter, "trsx", 0, 0, 0.5, 0, 0, time);
Stabilize3 = Stabilize(Text2, 1, 1, "2 point", Linear(0,185.294@1,185.888@2,186.56@3,187.341@4,188.216@5,189.169@6,190.279@7,191.388@8,192.576@9,193.794@10,195.232@11,196.435@12,197.701@13,198.966@14,200.107@15,201.154@16,202.107@17,202.654@18,203.279@19,203.638@20,203.669@21,203.607@22,203.482@23,202.794@24,202.263@25,201.404@26,200.497@27,199.591@28,198.56@29,197.419@30,196.404@31,195.404@32,194.372@33,193.497@34,192.497@35,191.544@36,190.466@37,189.247@38,187.716@39,186.435@40,185.247@41,184.138@42,183.247@43,182.544@44,182.372@45,182.497@46,183.076@47,183.654@48,184.716@49,186.169@50,187.435@51,189.107@52,190.638@53,192.372@54,194.107@55,195.654@56,197.263@57,198.654@58,199.732@59,200.638@60,201.185@61,201.388@62,201.247@63,200.779@64,200.06@65,199.247@66,198.513@67,197.701@68,197.076@69,196.435@70,196.122@71,196.044@72,196.029@73),
Linear(0,217.736@1,220.751@2,223.986@3,227.392@4,230.923@5,234.532@6,238.095@7,241.751@8,245.267@9,248.751@10,251.923@11,255.11@12,258.032@13,260.751@14,263.11@15,265.298@16,267.017@17,268.72@18,269.751@19,270.345@20,270.735@21,270.501@22,269.829@23,269.376@24,268.407@25,267.423@26,266.282@27,264.97@28,263.751@29,262.673@30,261.47@31,260.392@32,259.548@33,258.798@34,258.579@35,258.329@36,258.048@37,257.767@38,257.751@39,257.548@40,257.298@41,257.063@42,256.829@43,256.751@44,256.485@45,256.079@46,255.345@47,254.501@48,253.298@49,251.845@50,250.564@51,248.954@52,247.626@53,246.032@54,244.689@55,243.423@56,242.189@57,241.142@58,240.407@59,239.751@60,239.392@61,239.251@62,239.751@63,241.189@64,243.564@65,246.532@66,249.892@67,253.798@68,257.923@69,262.298@70,266.438@71,270.267@72,273.751@73),
1, 1, Linear(0,503.831@1,503.222@2,502.519@3,501.753@4,500.941@5,499.957@6,499.066@7,498.066@8,496.816@9,495.738@10,494.675@11,493.519@12,492.3@13,491.285@14,490.363@15,489.503@16,488.785@17,488.191@18,487.519@19,487.191@20,487.191@21,487.191@22,487.535@23,488.191@24,488.488@25,489.191@26,490.191@27,490.941@28,491.66@29,492.347@30,493.3@31,494.191@32,495.191@33,495.894@34,496.55@35,497.3@36,498.3@37,499.332@38,500.363@39,501.55@40,502.66@41,503.535@42,504.191@43,504.691@44,505.066@45,504.91@46,504.582@47,504.097@48,503.457@49,502.785@50,501.941@51,500.894@52,499.847@53,498.722@54,497.66@55,496.519@56,495.535@57,494.691@58,493.957@59,493.191@60,492.894@61,492.769@62,492.832@63,493.128@64,493.347@65,493.785@66,494.191@67,494.222@68,494.222@69,494.191@70,494.175@71,493.769@72,493.191@73),
Linear(0,247.488@1,245.488@2,243.363@3,241.113@4,238.816@5,236.363@6,234.066@7,231.722@8,229.254@9,227.035@10,224.894@11,222.847@12,220.832@13,219.113@14,217.582@15,216.175@16,215.066@17,214.113@18,213.316@19,212.894@20,212.785@21,212.863@22,213.191@23,213.832@24,214.3@25,215.082@26,216.019@27,216.879@28,217.691@29,218.379@30,219.222@31,219.925@32,220.597@33,220.894@34,220.972@35,220.925@36,220.832@37,220.613@38,220.222@39,220.019@40,219.816@41,219.613@42,219.316@43,219.3@44,219.629@45,219.988@46,220.879@47,222.144@48,223.816@49,225.754@50,227.832@51,229.972@52,232.16@53,234.379@54,236.566@55,238.566@56,240.394@57,242.082@58,243.472@59,244.363@60,245.066@61,245.316@62,244.582@63,242.66@64,239.488@65,235.582@66,230.925@67,225.613@68,220.019@69,214.363@70,208.988@71,203.785@72,199.019@73),
1, 1, 2*width/3, 2*height/3, width/3, 2*height/3, "default",
xFilter, "trsx", 0, 0.5, 0, 1, sqrt(((track2X-track1X)(track2X-track1X)) +((track2Y-track1Y)(track2Y-track1Y))) /sqrt(((track2X@@refFrame) -(track1X@@refFrame))((track2X@@refFrame) -(track1X@@refFrame))+((track2Y@@refFrame) -(track1Y@@refFrame))((track2Y@@refFrame) -(track1Y@@refFrame))),
atan2d((track2Y-track1Y),(track2X-track1X))-(atan2d(((track2Y@@refFrame)-(track1Y@@refFrame)),((track2X@@refFrame)-(track1X@@refFrame)))),
1, "v2.0", 1, "1/64", "luminance", 0.3, 0.59, 0.11, 0.75,
"use start frame", 0.5, "stop", 0, 0, 25, "track1", 167.999634,
200.399643, 201.191589, 233.591553, 74.49629, 293.902954,
110.780319, 324.0028, "track2", 487.552948, 519.953, 230.381653,
262.781616, 390.9574, 616.5486, 144.6086, 348.5547, "track3",
463.8, 496.2, 307.8, 340.2, 447.6, 512.4, 291.6, 356.4, "track4",
223.8, 256.2, 307.8, 340.2, 207.6, 272.4, 291.6, 356.4, float multiplier = Linear(0,0@25,1@49));
Double_targets_FILEOUT = FileOut(Move2D2, "/Volumes/Homunculus/MWD_related/Shake_Related/STB_dissolve_test/Double_targets.####.rla",
"Rla");
Select1 = Select(Linear(0,1@1,1@25,1@36,1@49), Stabilize3, Text2,
0);
Over2 = Over(Select1, Double_targets, 1, 0, 0);
// User Interface settings
SetKey(
"colorPicker.hex", "0",
"colorPicker.range", "32",
"globals.broadcastHighQuality", "1",
"globals.broadcastMonitorNumber", "2",
"globals.broadcastViewerAspectRatio", "script.defaultViewerAspectRatio",
"globals.cacheMode", "2",
"globals.consoleLineLength", "120",
"globals.displayThumbnails", "1",
"globals.enhancedNodeView", "0",
"globals.fileBrowser.favorites", "/private/var/automount/xlv3/home/paul2/;$HOME;/home/paul2//nreal/;/Applications/Shake/;/Applications/Shake/doc/pix/;/private/var/automount/xlv3/home/paul2//nreal/;/Applications/Shake3.50/;/Applications/Shake3.50/doc/pix;/private/var/automount/xlv3/home/paul/;/private/var/automount/xlv3/home/paul//nreal/;/;/Applications/Shake3.01/;/Applications/Shake3.01/doc/pix;/Users/riveteck/;/Users/riveteck/nreal/;/Applications/Shake3/;/Applications/Shake3/doc/pix;/v/;/v/Home_Depot/;/v/Greece/;/Users/Shared/;/v/MWD/MWD_General/Shake_related/paul/;/v/Greece/gc001/gc001_parthenon_Sourcefiles/Shake_files/paul/;/v/Greece/gc001/gc001_elements/;/v/Invincible/;/v/Greece/gc001/gc001_renders/paul/;/v/Greece/gc001/gc001_mongo2_elements/;/Volumes/;/Volumes/Thunderbolt_Fist_2/Paul_OT/;/v/Greece/gc001/gc001_parthenon_Sourcefiles/;/v/Greece/gc001/gc001_parthenon_Sourcefiles/Art/;/v/Greece/gc001/gc001_parthenon_Sourcefiles/Art/paul/;/v/Greece/gc001/gc001_mongo2_renders/;",
"globals.fileBrowserExactList", "0",
"globals.fileBrowserFilterList", "1",
"globals.fileBrowserFullList", "0",
"globals.fileBrowserHeight", "540",
"globals.fileBrowserImageList", "0",
"globals.fileBrowserLC1", "356",
"globals.fileBrowserLC2", "70",
"globals.fileBrowserLC3", "110",
"globals.fileBrowserLC4", "245",
"globals.fileBrowserLC5", "175",
"globals.fileBrowserLC6", "65",
"globals.fileBrowserLC7", "111",
"globals.fileBrowserRIntSet", "0",
"globals.fileBrowserSC1", "211",
"globals.fileBrowserSC2", "211",
"globals.fileBrowserSC3", "211",
"globals.fileBrowserSeqList", "0",
"globals.fileBrowserShortList", "0",
"globals.fileBrowserWIntSet", "1",
"globals.fileBrowserWidth", "790",
"globals.fileBrowserfullPath", "0",
"globals.fontBlue", "1",
"globals.fontGreen", "1",
"globals.fontRed", "1",
"globals.gridBlue", "0.15",
"globals.gridEnabled", "0",
"globals.gridGreen", "0.15",
"globals.gridHeight", "40",
"globals.gridRed", "0.15",
"globals.gridVisible", "0",
"globals.gridWidth", "40",
"globals.layoutTightness", "40",
"globals.multiPlaneLocatorScale", "1",
"globals.noodleABlue", "1",
"globals.noodleAGreen", "1",
"globals.noodleARed", "1",
"globals.noodleAZBlue", "0.4",
"globals.noodleAZGreen", "0",
"globals.noodleAZRed", "0",
"globals.noodleBWABlue", "0.4",
"globals.noodleBWAGreen", "0.4",
"globals.noodleBWARed", "0.4",
"globals.noodleBWAZBlue", "0.4",
"globals.noodleBWAZGreen", "0",
"globals.noodleBWAZRed", "0",
"globals.noodleBWBlue", "0.15",
"globals.noodleBWGreen", "0.15",
"globals.noodleBWRed", "0.15",
"globals.noodleBWZBlue", "0.4",
"globals.noodleBWZGreen", "0",
"globals.noodleBWZRed", "0",
"globals.noodleBlue", "1",
"globals.noodleColorCoding", "2",
"globals.noodleGreen", "1",
"globals.noodleRGBABlue", "0.7",
"globals.noodleRGBAGreen", "0.7",
"globals.noodleRGBARed", "0.7",
"globals.noodleRGBAZBlue", "1",
"globals.noodleRGBAZGreen", "0.4",
"globals.noodleRGBAZRed", "0.4",
"globals.noodleRGBBlue", "0",
"globals.noodleRGBGreen", "0.7",
"globals.noodleRGBRed", "0.7",
"globals.noodleRGBZBlue", "0.8",
"globals.noodleRGBZGreen", "0.2",
"globals.noodleRGBZRed", "0.2",
"globals.noodleRed", "1",
"globals.noodleStipple16", "1061109567",
"globals.noodleStipple32", "-1",
"globals.noodleStipple8", "-1431655766",
"globals.noodleTension", "0.25",
"globals.noodleZBlue", "0.4",
"globals.noodleZGreen", "0",
"globals.noodleZRed", "0",
"globals.paintFrameMode", "1",
"globals.pdfBrowserPath", "",
"globals.proxyTog.cycle", "-1,0,0,0,0,4",
"globals.renderModeTog.cycle", "2,0,0,2",
"globals.rotoAutoControlScale", "1",
"globals.rotoBuildColorBlue", "0.75",
"globals.rotoBuildColorGreen", "0.75",
"globals.rotoBuildColorRed", "0.375",
"globals.rotoControlScale", "1",
"globals.rotoFocusColorBlue", "0.9375",
"globals.rotoFocusColorGreen", "0.375",
"globals.rotoFocusColorRed", "0.5",
"globals.rotoFocusSelectColorBlue", "0.5",
"globals.rotoFocusSelectColorGreen", "1",
"globals.rotoFocusSelectColorRed", "0.5",
"globals.rotoKeyedColorBlue", "1",
"globals.rotoKeyedColorGreen", "0.65",
"globals.rotoKeyedColorRed", "0.45",
"globals.rotoNormalColorBlue", "0.125",
"globals.rotoNormalColorGreen", "0.75",
"globals.rotoNormalColorRed", "0.75",
"globals.rotoNormalSelectColorBlue", "0.0625",
"globals.rotoNormalSelectColorGreen", "1",
"globals.rotoNormalSelectColorRed", "0.0625",
"globals.rotoPickRadius", "15",
"globals.rotoTangentColorBlue", "0.125",
"globals.rotoTangentColorGreen", "0.5625",
"globals.rotoTangentColorRed", "0.5625",
"globals.rotoTangentCreationRadius", "10",
"globals.rotoTempKeyColorBlue", "0",
"globals.rotoTempKeyColorGreen", "0.5",
"globals.rotoTempKeyColorRed", "1",
"globals.rotoTransformIncrement", "5",
"globals.showActiveGlows", "2",
"globals.showConcatenationLinks", "2",
"globals.showExpressionLinks", "2",
"globals.showTimeDependency", "2",
"globals.textureProxy", "1",
"globals.thumbAlphaBlend", "1",
"globals.thumbSize", "15",
"globals.thumbSizeRelative", "0",
"globals.viewerAspectRatio", "script.defaultViewerAspectRatio",
"globals.viewerZoom", "1.0/proxyScale",
"globals.virtualSliderMode", "0",
"globals.virtualSliderSpeed", "0.25",
"globals.warpBoundaryNormalColorBlue", "0",
"globals.warpBoundaryNormalColorGreen", "0.5",
"globals.warpBoundaryNormalColorRed", "1",
"globals.warpConnectionNormalColorBlue", "0.8",
"globals.warpConnectionNormalColorGreen", "0",
"globals.warpConnectionNormalColorRed", "0.4",
"globals.warpDisplacedNormalColorBlue", "1",
"globals.warpDisplacedNormalColorGreen", "0",
"globals.warpDisplacedNormalColorRed", "1",
"globals.warpLockedColorBlue", "0.6",
"globals.warpLockedColorGreen", "0.6",
"globals.warpLockedColorRed", "0.6",
"globals.warpSourceNormalColorBlue", "1",
"globals.warpSourceNormalColorGreen", "0.8",
"globals.warpSourceNormalColorRed", "0",
"globals.warpTargetNormalColorBlue", "0.7",
"globals.warpTargetNormalColorGreen", "0.2",
"globals.warpTargetNormalColorRed", "0.2",
"globals.webBrowserPath", "",
"mainQuad.bot", "0.421668738",
"mainQuad.left", "0.462233841",
"mainQuad.right", "0.671536148",
"mainQuad.top", "0.421668738",
"mainWin.height", "917",
"mainWin.tabChild1", "0.Image",
"mainWin.tabChild10", "0.User",
"mainWin.tabChild11", "0.Curve_Editor_2",
"mainWin.tabChild12", "0.Node_View_2",
"mainWin.tabChild13", "0.Time_View",
"mainWin.tabChild14", "1.Parameters1",
"mainWin.tabChild15", "1.Parameters2",
"mainWin.tabChild16", "1.Globals",
"mainWin.tabChild17", "2.Viewers",
"mainWin.tabChild2", "0.Color",
"mainWin.tabChild3", "0.Filter",
"mainWin.tabChild4", "0.Key",
"mainWin.tabChild5", "0.Layer",
"mainWin.tabChild6", "0.Transform",
"mainWin.tabChild7", "0.Warp",
"mainWin.tabChild8", "0.Other",
"mainWin.tabChild9", "0.Lens_Predef",
"mainWin.width", "1594",
"mainWin.xPos", "3",
"mainWin.yPos", "36",
"nodeView.Double_targets.t", "1",
"nodeView.Double_targets.tnChannel", "0",
"nodeView.Double_targets.tnTime", "1",
"nodeView.Double_targets.tnVisible", "1",
"nodeView.Double_targets.x", "1600",
"nodeView.Double_targets.y", "160",
"nodeView.Double_targets_FILEOUT.t", "0",
"nodeView.Double_targets_FILEOUT.x", "1829.40649",
"nodeView.Double_targets_FILEOUT.y", "37.14833",
"nodeView.Move2D2.t", "0",
"nodeView.Move2D2.x", "1881.40649",
"nodeView.Move2D2.y", "127.148331",
"nodeView.Over2.t", "0",
"nodeView.Over2.x", "1528",
"nodeView.Over2.y", "-32",
"nodeView.RotoShape2.t", "1",
"nodeView.RotoShape2.tnChannel", "0",
"nodeView.RotoShape2.tnTime", "1",
"nodeView.RotoShape2.tnVisible", "1",
"nodeView.RotoShape2.x", "1865.40649",
"nodeView.RotoShape2.y", "198.148331",
"nodeView.Select1.t", "0",
"nodeView.Select1.x", "1386.58142",
"nodeView.Select1.y", "103.392075",
"nodeView.Stabilize3.t", "0",
"nodeView.Stabilize3.x", "1249.75891",
"nodeView.Stabilize3.y", "169.87558",
"nodeView.Text2.t", "1",
"nodeView.Text2.tnChannel", "0",
"nodeView.Text2.tnTime", "1",
"nodeView.Text2.tnVisible", "1",
"nodeView.Text2.x", "1346.21582",
"nodeView.Text2.y", "268.6597",
"nodeView.xPan", "-853.072632",
"nodeView.yPan", "42.6890869",
"nodeView.zoom", "0.4613173",
"pixelAnalyzer1.aStatToggleState", "0",
"pixelAnalyzer1.accumulate", "0",
"pixelAnalyzer1.bStatToggleState", "0",
"pixelAnalyzer1.bit16ToggleState", "0",
"pixelAnalyzer1.bit32ToggleState", "1",
"pixelAnalyzer1.bit8ToggleState", "0",
"pixelAnalyzer1.gStatToggleState", "0",
"pixelAnalyzer1.hStatToggleState", "0",
"pixelAnalyzer1.hex", "0",
"pixelAnalyzer1.imgToggleState", "0",
"pixelAnalyzer1.lStatToggleState", "1",
"pixelAnalyzer1.offToggleState", "0",
"pixelAnalyzer1.pxlToggleState", "1",
"pixelAnalyzer1.rStatToggleState", "0",
"pixelAnalyzer1.sStatToggleState", "0",
"pixelAnalyzer1.vStatToggleState", "0",
"spawnedViewerCount", "0",
"timeBar.current", "36",
"timeBar.high", "73",
"timeBar.incr", "1",
"timeBar.low", "1",
"timeView.ctrls.selGroup", "0",
"timeView.list.open.Double_targets.cycle", "-2,-2,0",
"timeView.list.open.Over2.cycle", "-2,-2,0",
"timeView.list.open.RotoShape2.cycle", "-2,-2,0",
"timeView.list.open.Text2.cycle", "-2,-2,0",
"timeView.wSpace.constDisp", "0",
"timeView.wSpace.dispInOut", "1",
"timeView.wSpace.endTime", "100",
"timeView.wSpace.startTime", "1",
"timeView.wSpace.trim", "0",
"updater.mode", "2",
"vDesk.0.chanTog.0.cycle", "4,0,0,0,0,0",
"vDesk.0.chanTog.1.cycle", "4,0,0,0,0,0",
"vDesk.0.compareMode", "0",
"vDesk.0.compareTog.cycle", "-1,0,0,0,-1",
"vDesk.0.displayModeA", "0",
"vDesk.0.displayModeB", "0",
"vDesk.0.dodNodeSerial", "SetDOD(Select1, 0, 720, 0, 486);",
"vDesk.0.dodToggle", "0",
"vDesk.0.g", "1",
"vDesk.0.h", "457",
"vDesk.0.i", "0",
"vDesk.0.ih", "824",
"vDesk.0.isActive", "1",
"vDesk.0.iw", "1168",
"vDesk.0.lookupNodeSerial0", "Truelight_VLUT_(ViewerDodSelect, \"none\", \"monitor\", \"log\", 0, 0, 0, 0, 0, 0, 1, 0.01, 16, 0.1978, 0.4683);",
"vDesk.0.lookupNodeSerial1", "ViewerLookup1_(ViewerDodSelect, 1, 0, 2, 0, 0, 0, 95, rBlack, rBlack, 685, rWhite, rWhite, 0.6, rNGamma, rNGamma, 1.7, rDGamma, rDGamma, 0, rSoftClip, rSoftClip);",
"vDesk.0.lookupTog.cycle", "1,0,0,0",
"vDesk.0.lookupToggle", "0",
"vDesk.0.monitoredNodeA", "NRiScript1.Over2",
"vDesk.0.numViewerLookups", "2",
"vDesk.0.numViewerScripts", "6",
"vDesk.0.oscAutoKeyOnOff", "1",
"vDesk.0.oscLockTog.cycle", "1,0,0,0",
"vDesk.0.oscOnOff", "1",
"vDesk.0.oscTog.cycle", "1,0,0,1",
"vDesk.0.roiOnOff", "0",
"vDesk.0.scriptNodeSerial0", "ApertureMarking(riNode, \"Auto\", 0, 0, 1, 1, 1, 1, 1, 1, 3, 1, 0.2, academyDefaultRed, academyDefaultGreen, academyDefaultBlue, academyDefaultAlpha, academyDefaultLineWidth, 1, 0.4, academyDefaultRed, academyDefaultGreen, academyDefaultBlue, academyDefaultAlpha, academyDefaultLineWidth, 1, 0.6, academyDefaultRed, academyDefaultGreen, academyDefaultBlue, academyDefaultAlpha, academyDefaultLineWidth, 0, 0.8, academyDefaultRed, academyDefaultGreen, academyDefaultBlue, academyDefaultAlpha, academyDefaultLineWidth, 0, 0.5, academyDefaultRed, academyDefaultGreen, academyDefaultBlue, academyDefaultAlpha, academyDefaultLineWidth, 0, 0.25, academyDefaultRed, academyDefaultGreen, academyDefaultBlue, academyDefaultAlpha, academyDefaultLineWidth, 1, 1, 1, 1, 3, 0, 0.2, fullDefaultRed, fullDefaultGreen, fullDefaultBlue, fullDefaultAlpha, fullDefaultLineWidth, 1, 0.4, fullDefaultRed, fullDefaultGreen, fullDefaultBlue, fullDefaultAlpha, fullDefaultLineWidth, 1, 0.6, fullDefaultRed, fullDefaultGreen, fullDefaultBlue, fullDefaultAlpha, fullDefaultLineWidth, 1, 1, 1, 1, 1, 1, 20, 0.25, tvDefaultRed, tvDefaultGreen, tvDefaultBlue, tvDefaultAlpha, tvDefaultLineWidth, 1, 10, 0.5, tvDefaultRed, tvDefaultGreen, tvDefaultBlue, tvDefaultAlpha, tvDefaultLineWidth);",
"vDesk.0.scriptNodeSerial1", "ViewerScript_2_(riNode, 1, 1, 1, Input.width/2, Input.height/2);",
"vDesk.0.scriptNodeSerial2", "ViewerScript_3_(riNode, 3, 0, .5);",
"vDesk.0.scriptNodeSerial3", "ViewZ(riNode, 0, 0, 0, 5000000, 1, 100);",
"vDesk.0.scriptNodeSerial4", "FloatView_(riNode, 2, 0, 0, 1, 1-red1, 1-green1, 1-blue1);",
"vDesk.0.scriptNodeSerial5", "TimeCode_(riNode, \"Timecode\", 0, 0, 0, 0, 1, 1, 1, 0, 0, 0, 1, .5, 20, 20);",
"vDesk.0.scriptTog.cycle", "-1,0,0,0,0,0,0,-1",
"vDesk.0.scriptToggle", "0",
"vDesk.0.updateModeA", "1",
"vDesk.0.updateModeB", "1",
"vDesk.0.updateTog.0.cycle", "-1,0,0,1",
"vDesk.0.updateTog.1.cycle", "-1,0,0,1",
"vDesk.0.w", "666",
"vDesk.0.x", "0",
"vDesk.0.xPan", "93",
"vDesk.0.xliderValue", "0",
"vDesk.0.y", "0",
"vDesk.0.yPan", "8",
"vDesk.0.zoom", "0.6547092",
"vDesk.viewers", "1"
try it out and see what I'm seeing or just set me straight on the syntax.
thanks Deke for replying
-Paul
