May be i missed the point about baking, but i tried this:
I made a plane surfaces with a shader network applied to it. the texture includes bump, diffuse and specular rolloff maps. the surfaces is illuminated with caustics and Gi.
when i batch bake the surface into a texture i only get the color map with the correct lightning but without any bump spec etc..
what happend with them? how can i include them into the batch bake. or do i need to apply it afterwards?.
Okay a concepth here. About specular and bump as effects.
Global illumination is constant so the relukt does not vary based on where your camera is, same applies to diffuse.
Specular, Specular is a Nasty beast it simulates the unperfect reflection of the lightsource. (As such realword does not have anything called specular), now everyone whos ever observed a mirror knows that whats seen in the miiror depends on where you stand. Now thismeand theres no way your going to succed in baking specular, or atleast it will not look like specular anymore.
Now for bump, bump is affected by direct lightning, but because it has no true 3d shape its not realy affected much by gloabal illumination tricks like fg and photonmapping. Now bump can be partialy baked, it probably was the effect just was so wahsed out (because in a full fg lightning situation it will) thet you dbarely notice it. NOw id estimate that 50-75% of the final bump effect is from how specular and reflections play on the surface wich offcourse cant be beaked haead of time.
