Odd, I replied to this last week, and it doesn't appear to have registered. Anyways....
All you need to do is use the "extend first frame" function in the loader, and offset the appropriate number of frames. (3?)
You can also use the global in function, however, if this loader is the backmost layer of your flow, this cause problems rendering the first 3 frames.
