Ok, I have a box, I delete one of the face ( polygon ) How do I recreate it without using the fill hole ? Is there a way I can build a face the same way it can be done in Max ? Click on vertex 1, then 2 , 3.. until the polygon is closed ..
Thanks
Thanks
I believe it's called Add to Polygon. You click on edges, not faces, but it does what you want.
-Steve
