How to delete animation from skeleton
I have imported scene (from Si3D to XSI) with skeleton animation. In this animation parts fs skeleton are moving along the curve. When I delete all key frames and this curve (along wich these parts are moving), there comes a problem. This skeleton is no longer moving but parts which were attached to curves, are still attached. I cant move them.
Have you tried to delete all constraints and animation in SI3D SPx before transfering to XSI?
In SI3D, eventhough path animation was threated differently from other constraints, which meant that if you deleted the animation keys you would lose the path constraint
In XSI, path animation is a real constraint, with a parameter controlling the distance along the path that your object is constrained to. This constraint will continue to exists regardless of the fact that you deleted all the keys.
To remove the path constraint, select the object, and use delete constraint, or if you have display info on, you can also select the constraint itself (“path”) and delete that.
Olivier Ozoux, SOFTIMAGE Special Projects
The opinions expressed in this forum are my own, and might not represent’s Avid or SOFTIMAGE official position on the subject.
