Thank you, it was my mistake.
I am tring to make a script that will make some kind of conversion between polys and nurbs. I wanna convert some of poly models to nurbs. Because I couldn't find any tool that can do this conversion I wanna try.
The idea is to slice polygonal mesh into n number of pieces and on the edges draw curves and loft these curves into nurbs.
All would be easier, but it seems that we can't make curve on the intersection of two poly meshes, and I had to make n number of planes intersecting my poly mesh, do boolean and draw curve on the intersection.
I know that will appear problem with parametrization of these curves but I will try to solve it.
Thak you for support.
dsinisa
www.sinartstudio.com
