How to do a "radial array" in maya?
ok, so I know you can set #'s when you duplicate of course. But I can't seem to get it to work quite as properly as this tutorial (for 3DS Max) shows an array working. If anyone's got a hint then, please enlighten me!
here's what i want to be able to do (max vers.)
http://www.3dspline.com/radialArray.htm
why not just do it in max you say? I want to use maya nurbs (nuff said). note that this is for designing features in a sports car wheel rim..
thanks for reading!
-r
http://www.slipthru.com
insert key - allows you to change the location of your object's pivot (first step in the tute) i suspect you'll find this is all you need!
comeback for more if not!
yeah, I had also insert-moved the pivot. unable to align the pivot exactly to where I wanted, so I kind of eyeballed it (stick an interface box so that the "source" pivot's manipulate line is driectly above the box, then select the pivot to move and drag it down so that it's placed above the box as well)
then I duped and set the number of copies plus how much they should rotate by (every 35 degrees) but it still didnt work properly, they just jumbled up into the 1st quarter of the circle's area.. hmm. Stumped.
you know you can still do your normal snapping when you are adjusting the pivot...so should be easy enuf to get it where you want it. if you just do this around wrld origin, it'll be even easier, just snap it to the grid origin.
after doing this, and you pop a rotation into the correct box in dup options, and a numebr of copies...all should be fine. nothing special is going on. i'd check to make sure that you are indeed moving the pivot of the the thing you are duplicating, and it is that transform you have selected when you do your duplicaitons.
keep trying.. or maybe orientation of your local axis is a bit funny? ...when you;ve taken the pivot to your radial centre, there is an axis that clearly sticks out perpendicular to the radial plane? the axis you are using to duplicate around.
experiement w a box, just to convince yourself it does what you expect.
