Hi, i've tried Rawkee but it only supports 32bit systems and i have Win XP X64 so ican't load it. When i export as .vrml2 the results are not good (screwed up animation). The best (but still not good) results i have are exporting as .fbx to Max then exporting as .vrml to Wire Fusion (my final app). What i want to know is if there is any plugin for Maya 2008 X64 for .vrml. Or if there is anyway of getting Rawkee to work (any version of Maya but on an X64 OS)
When you went over with fbx did you bake all keys down?
Maya can do allt of stuff vrml could never do.
The animation exports OK without baking but it all auto-plays (without any way of turning it off) when imported into Wire Fusion, only way to avoid this is .vrml but no plugin for Maya 2008 x64, which is the problem.
Well vrml is a quite trivial text based format so cant you just edit the play script to wait for your condition? If you need to do this in bulk just do search and replace with sed or something.
You can probably quite trivially find out the changes needed y comparing the outputs of both tools.
Error: Backend Fetch Failure
