I wander how to get the closest point on surface about a assign point use MEL.I know there is a node named closestPointOnsurface can do it ,but i need use MEL command.
QUOTE(nick98 @ 04/24/06, 02:42 PM) [snapback]235195[/snapback]
Hi
Maya Bouns Tool you can get a plugin closestPointOnMesh.mll
thorugh that you can do it
there is also nearestPointOnMesh.mll delivered with Maya 7 isn't it?
I believe there are two modes you can use the command with:
1. create a nearestPointOnMesh/closestPointOnMesh-node and connect it with your stuff and get the values from the attribute plugs.
2. use it directly via mel with a specified mesh and query the values directly.
there are many places in maya where a node is used as mel command by making it temporarily then querry and delete the node.
Nah more detailed I mean: first you can create such a node and connect the closest point with a locators translation-attributes so you can move the node and interactively see what happens where and when. Know what I mean? Sometimes useful for character rigs and stuff.
On the other hand you can just send the mel command and get the values you want without anything being visually created. You just query something.
Is that 2 ways enough? ;]
Yes i understand whtat you say but in maya theres sometimes a understandable confusion on wether a command is:
The 3 most OVIOUS alternative is rare indeed!
Reviving this old thread. It seems like creating a temporary node and sampling it is the way to go.
Here’s a bit of python for returning either a list of nodes, or a list of uvVals
You will need a sample surface, an array of points, and a choice between uvVals or nodes.
Select your sample surface and assign it with ‘sampleSurface = cmd.ls(sl=True)[0]’
Supply an array of points to sample. Select the objects - locators or whatever, and run this:
points = [] for i in cmd.ls(sl=True): point = cmd.xform(i, q = True, t = True, ws = True) points.append(point)
Here is the function to return either values or nodes, depending on what you need
import maya.cmds as cmd import maya.mel as mel gA = cmd.getAttr sA = cmd.setAttr cA = cmd.connectAttr cN = cmd.createNode def getClosestPointsOnSurface(points, sampleSurface, type = 'nodes'): returnVal = None cposNodes = [] vals = [] split = sampleSurface.split('_') surf = cmd.listRelatives(sampleSurface, c = True, ni = True, type = 'nurbsSurface')[0] if type == 'nodes': for i in range(len(points)): cPos = cN('closestPointOnSurface', ss = True, n = '%s_%02d_cPos' % (split[0], i)) cA('%s.worldSpace[0]' % surf, '%s.inputSurface' % cPos) sA('%s.inPosition' % cPos, points[i][0], points[i][1], points[i][2]) cposNodes.append(cPos) returnVal = cposNodes if type == 'vals': for i in range(len(points)): cPos = cN('closestPointOnSurface', ss = True) cA('%s.worldSpace[0]' % surf, '%s.inputSurface' % cPos) sA('%s.inPosition' % cPos, points[i][0], points[i][1], points[i][2]) u = gA('%s.result.parameterU' % cPos ) v = gA('%s.result.parameterV' % cPos ) vals.append([u,v]) cmd.delete(cPos) returnVal = vals return returnVal
Finally, the example command to run
cposNodes = getClosestPointsOnSurface(points, sampleSurface, type = 'nodes') uvVal = getClosestPointsOnSurface(points, sampleSurface, type = 'vals')
sampleSurface
Result: u’face_def_surf’
points
Result: [[-9.934378258772887e-05, 56.52158927169142, 13.096842334001089],
[-1.2986319080810456, 56.573714757526794, 13.019487214074514],
[-2.3988572845724603, 56.81671021609732, 12.825554268688125],
[-2.887766742811174, 57.28272070017139, 12.744081627653983],
[-2.9564472997142497, 57.50138883790414, 12.769442914295668],
[-2.879458555286166, 57.672685482014, 12.879225548927492],
[-2.192046597368875, 57.79139587725608, 13.341300849584687],
[-1.140138085103556, 57.811148683446966, 13.800117232849214],
[-0.0007878168005395606, 57.81488077210223, 13.925655903295926],
[1.1383058170299245, 57.81117323292432, 13.796743621692903],
[2.191000144083259, 57.79144462951285, 13.339583497622566],
[2.879303203717313, 57.67272400054267, 12.878886599401458],
[2.9563649858235075, 57.50140832665556, 12.769194174384452],
[2.887671243257571, 57.282744486066534, 12.743798227096866],
[2.398733183100953, 56.81673428803417, 12.825116354417371],
[1.2984150038822726, 56.57377235530355, 13.018506756780637]]
uvVal
Result: [[1.0004341542613102, 0.2301692487434747],
[1.2064782285634066, 0.21627448891449497],
[1.3722637684008845, 0.28391258246162415],
[1.509186903505303, 0.3387848920830241],
[1.563309727886676, 0.36916657892685023],
[1.6002270473405233, 0.369506881916711],
[1.6601835924689776, 0.24208844308577132],
[1.7978056591853022, 0.10984749089757448],
[1.9998468370341644, 0.10376750763367472],
[0.20215057952270601, 0.10949474728688213],
[0.33988142055839465, 0.24195245274626373],
[0.39978054787266903, 0.3695019564741386],
[0.4366984973876268, 0.3691695706042126],
[0.4908336188623674, 0.3387896663238795],
[0.6277812551226932, 0.2839743883775245],
[0.7935635789475637, 0.21646212421961572]] #
cposNodes
Result: [u’face_00_cPos’,
u’face_01_cPos’,
u’face_02_cPos’,
u’face_03_cPos’,
u’face_04_cPos’,
u’face_05_cPos’,
u’face_06_cPos’,
u’face_07_cPos’,
u’face_08_cPos’,
u’face_09_cPos’,
u’face_10_cPos’,
u’face_11_cPos’,
u’face_12_cPos’,
u’face_13_cPos’,
u’face_14_cPos’,
u’face_15_cPos’] #
