How To Get The Current Working Directory?
Hi,
I have developed a Plug-In for Maya. In my UI I have three pictures which are located in the scrips folder. So they are in the same folder as the sourcefiles of my Plug-In. But if the Plug-In is installed at another system I have to find out where the script folder is located. I know normaly it is in the home directory but this is not always sure.
Now I tried to use the "os.getcwd() " Method but I get the directory from which I opened the scene and not the directory where the sourcefiles are.
So I thought I can readout the PYTHONPATH varibale which is located in the maya.env file. But I don’t know how to do this. At first there is the same problem with the path to this file. Secondly I don’t know if there is any way to read out the variable with python over Maya.
I would be very thankful if anyone can give me a solution to this problem.
Thanks
simply you can use
sys.path[0]
to find from where the python script is got called
I tried
sys.path[0]
but if I run my script in Maya I get this back:
C:\Programme\Autodesk\Maya2008\bin
But thank you anyway I’ve realy forgotten this command .
Oh I’m so stupid. I think I’ve tried all versions to get the path but the only thing I’ve never used is simply
self.uiImage =‘.\uiImage.bmp’
using the relativ path. doh
Thank you for help.
I recommend using the variable __file__
