Hi,
I tried to import an EPS logo into Maya 7 but it won't bring it in.
Is there a special way it has to be saved or something?
Thanks
Hi,
Thanks
try OBJ
What is OB7?
I downsaved the illustrator file to version 3 and converted everything to curves.
I even tried to import the AI file with the import illustrator document menu choice.
It doesn't come up with an error - but nothing is imported.
Help!
you should be using ver 6 or 7. But note text and effects needs to be convertted to outlines first!
Also are you sure the text might be HUGE so youd not be seing anything what does the outliner say, you may need to readjust the near far clippingplanes.
Also for ovious reasonts anything bitmap in the file si not importted
Hello,
I just decided to give this a try just for the hell of it, and I was actually successful at importing a little EPS blob I drew in Freehand. I saved it as a generic EPS, and then in Maya 7, I did the import, and chose the 'EPS' filetype.
At first, I didn't think it worked. The screen half blinked, but nothing. Then I zoomed way out, and there it was, sitting far on top of everything else.
The problem I am having now is the MOVE arrows are not centered on my lil blob, and is pretty far off center. It seems Maya is just arbitrarly picking a center point for it.
How do I center the "center point" on my blob?
QUOTE(Scorponok @ 05/29/06, 10:24 PM) [snapback]238491[/snapback]
No its not its placing it at the origin. Anyway use center pivot
