Hello
I want to use the UltraEdit Syntax Highlighting for maya 7.0, but I dont know how to use it. the download has a txt. and I cant figure out how to install it.
any help will be appreciate.
Thanks for your help.
Rent
Hello
Rent
QUOTE(rentboy @ 09/28/06, 12:12 PM) [snapback]248766[/snapback]
Hello
Rent
well, I suppose this is vaguely to do with MEL.. ![]()
basicallly, ultraedit uses a single wordfile in which it stores all the commands for every language it has colorization for... look in your ultraedit install folder and you should find WORDFILE.TXT you simply need to replace this one with the one you downloaded OR you need to paste the contents of the file you downoaded into the END of WORDFILE.txt.. it depends what's in it.. open them both into a text editor and you should be able to figure it out...
failing that, look in the ultraedit help files for "syntax colouring" or "wordfile"
:nathaN
