How to make live water waves script?
Hello Guys,
I sent the same post to the modelling/animation section but the feedback was not satisfactory. If you know how to solve the following problem or if you have soem kind'a MEL please send it to me over my personal e-mail adress. You can find it at the bottom of the page.
I have some kind of a problem. I want to make a curve on my created surface with Make Live option so that when i animate my surface, the curve will update itself automatically.
The thing is, this surface is going to be a sea-surface. I am generating the surface with the plugin WaterWaves. (You can find it under MEL SCRIPTS) Then i make the created surface live and draw my curve on it. The curve generates correctly but when the surface is animated, the curve is not updated.
I think this is because the surface is not animated with keyframes but expressions. Is there a way to combine parametric deformations with live surface curves ?
Thank you for any help...
Ozan Gunceler
ozangunceler@ultratv.net
