In the render globals there is a setting that controls how many images are rendered per frame.
Its called "By Frame".. so if you have 100 frames, and you set
by frame to 0.5 you'll end up with 200 images, if you make a movie out of that at your normal fps.. you should have it at half speed.
hope this helps.
