How to morph between to logos using a 2d fluid?
I'm trying to do a morph between to logos using a 2d fluid container. I'm currently importing an attribute map as density in the paint fluid tools. However, this only works for the initial state of the fluid. Is there a way to add a secondary state, or how could this be accomplished?
i too have the same problem. do inform me if you have found the soultion through mail.:-thanthiram@yahoo.co.in. i too will inform u as soon as i find it.see ya
venkadasalu
Having two key shapes is tricky. Having a shape form from chaotic clouds is simply a matter of running the simulation starting from the shape and then reversing the playback of the cache( see other posts here for in how to do this ). In this case perhaps you could use two fluids. The first one diffuses into a cloud and becomes transparent. The second does the same, only in reverse. So the logo would go to a chaotic looking cloud and then to the other logo shape. Fading between two fluids might look a bit better than cross dissolving the frames played backwards.
Having the smoke move directly to the second shape is harder to do. Doing the above coupled with a few attractive newton forces placed in the shape of the opposing logo might help.
Duncan
Thanks for the suggestion, but how would you use newton forces to do this? Is there a way to use an alpha (or luminance) image as an attractor?
The basic idea would be to approximate the shape of your character with a few newton forces. This way when you do the cross dissolve style technique the cloud is moving in roughly the general location at the point of the dissolve rather than simply diffusing. You can't use alpha as an attractor. Perhaps painting velocities might help.. if the velocity grid is set to static then you can simply paint where you want the smoke to go.
Another possibility is to use geometry emission and then morph the shape of your geometry( one generally wants high dissipation when doing this ). This looks a bit like smoke streaming off of a changing shape.
Duncan
Thanks for your suggestion Duncan, but I was looking for a quick method to create organic mattes for use in 2d transitions. I have tried it using forces, but the fluid spreads out and splits into many particles.
